Spec is only 44 ft/lbs which isnt much and when you loosen one bolt, the other one is instantly loose. So when you are running the new bolts in, I always run one bolt in until it starts to lift the injector hold down on the other bolt side, then run that bolt in until it becomes snug. Then I do my version of the torque sequence. As long as the injector takes some force to full out, it is seated. And I dont remember you saying you had a miss or crankcase pressure, which you would have if the injector was letting compression into the rocker box.
