I think I know the answer, I'm looking for 2nd opinion, with $$$ of injectors I don't want to guess wrong.
My last trip to my camp I was driving my 06 3500 4x4 dually, & whenever putting load on truck i.e. hill climb, or running above 71 mph, I would get an audible chime alert ans grid hearer on flash on the dash, I would clear after dropping below 70, and stayed cleared unless running above 71 mph after about 2 min there the grid heater/chime would come back on.
I have searched several forums, the consesus that I can glean is that this is some sort of indicator of high return rate/poor injector flow.
My truck has 230K on odometer I do not know if this is the original set, if you will recall earlier, this past Feb. I posted about algae in my tank (that issue is sorted out); but as result of that crud I had to replace FCA to restore correct fuel pressure regualtion that was allowing 22Kpsi at idle, now I'm wondering if "it is just time" for the injectors, or should I also be looking for something else?
One of the folks at DDP motor sports suggested I might be having a grid heater issue, I checked that out all looked good there, should I be looking at a rail fuel pressure relief valve ???
If I do decide on injectors what else in the fuel system should I be looking to replace at same time to keep me from having to do this again anytime soon?
Do I need to park the truck for now or can I keep driving it at the 70 mph "high limit" where alarm does not seem to come on?
Also could someone point me to a good thread to review what injectors to use, more specifically which to avoid?
Thank You in advance
Tim
Tim
