reddge, he has a 12v, not 24.
The 370 marine injectors are a great power boost. Since you have the 160 pump, you
may need to also get a set of 181, or 191 delivery valves. , to make those injectors work well.
If your transmission is bone-stock, I would suggest a different cam plate first. The 47RH trannys won't take as much power as a later model with a 47RE will.
With all of my engine mods together, I've gained almost 2 mpg. Not bad considering I've added approx. 130hp.
Depends a lot on how you drive though.
Only heard good things about Piers.
I have one of their turbos.
