I have a 2011 Ram 2500 (first Diesel ever) that I purchased new. Since the begining I have experienced some strange fuel efficiency issues. At times I get 17 MPG on the highway at other time I get about 12 MPG under the same or similar conditions.
I can tell when the fuel efficiency is good and when it is crappy by watching the instant milage indicator. When I am going downhill it will peg to the right when it is running good, but won't go above 20 MPG when running crappy. It is not posting any codes and doesn't feel any different than when it is running good.
It seems that sometimes I can pull over, turn the ignition off and restart and it will run better but other times that doesn't help. It remindes me of the symptons that would indicate a stuck choke on an old carburetor gas engine.
I have about 16000 miles on the truck, have performed all recommended service and have had it into the dealer specifically to have the fuel milage issue addressed. They didn't find any codes, but did upgrade the engine software which interestingly added about 1 MPG to both the crappy and good Avg. MPG.
I have validated the accuracy of the Avg. MPG readings by manually calculating the MPG at fill-up. It is spot on (within . 1 MPG Average).
What is really frustrating is their attitude that they can't do anything to find the problem unless there is an engine code posted. I have called other dealers in my area and get the same answer "We can't do anything unless there is an error code".
