I've been having a hard start problem ever since I put the FASS system on my truck and I think I have finally found the problem. The steel tubing on the top of the fuel tank module suction where the quick connect attachs is rusted and leaking air. I pulled the tank out of the truck and after having priced new modules I'm trying to rebuild the one I have. I have new fittings made up to use two of the four openings on the top of the fuel module so I can use threaded fittings. One for the suction and one for the return. My problem is that I haven't seen the original type of tubing that was used for the suction and return lines and I need something that will work with a Push-Lok fitting or a hose barb. I know the Push-Lok hose works for external diesel fuel lines but I'm not sure it will hold up to being submerged in diesel. Has anyone used the 601 or 801 type hose in this type of application or know of a hose that will work and where I can get it? I need something with a 3/8 ID. Thanks! And sorry for gettin wordy.
Chris
Chris
