Fuel Pressure Gauge
EGT & boost gauges
Weight distributating(sp?) hitch
What's the best way to permanently install a fuel pressure gauge? So that there is no or extremely minimal possibility of causing a fuel leak?
Big MAK
98. 5 ISB 5spd 4x4 Quad Cab 3500, 4" Exhaust elbow down, PowerMax1, dang near everything else
https://www.turbodieseltrucks.com
Say, Mark, didn't Chip Fisher talk about that on Saturday? I was busy running around and trying to get a few pix, so I missed much of his talk (I know guys kept you quite busy, too!), but I did see him pointing out which fittings on the filter cover to tap into to look for which pressures. I bet if you e-mailed him, he'd be able to answer your question. He should be back in NH by now - he said he and Jack were leaving Tulsa for a straight run home.
Bruce Reynolds - Y2K 2500 QC 4X4 Sport, black 3. 54 auto, EVERY option but Cab Lights. K&N filter, 275HP Injectors, VA box on order. Much more... Tag: RAMPAGE
That's right Bruce, Chip did talk about it (that was good timing). What I'm trying to decide is if it's safe to put a pressure gauge in and leave it there for full time monitoring -- in the cab. Although, I've almost talked myself out of it as not necessary. I think I'll have Chip overnight me a PrimeLoc system so I can put it in this weekend and diagnose it myself (PrimeLoc has a built in pressure gauge; under the hood) and tell if it's really low pressure or not. I hate that drop-in cannister type of filter anyways, especially knowing the ISB spin-on filter has better filtration. That way I have the pressure gauge on the PrimeLoc and better filtration besides.
Bomb on!
Big MAK
Mark,
What is the correct fuel pressure range after the filter? I have thought about installing a pressure gage. When I was fishing we had one for the 671 Jimmy. When the pressure dropped below 60PSI it was time for a filter change.
Joe George
Eureka, CA
'95 2500 CC auto 4X4,Combo EGT/boost guage,custom switch panel,PacBrake,Torque plate,BD valve body,Automatic motorhome steps on both sides,Foldacover hard bed cover,Cummins chrome kit,Black steel grill guard,Front hitch receiver
