Just installed the Nordskog
I installed the Nordskog this weekend. I u-bolted the sender to the hydraulic booster line bracket that bolts to the master cylinder, and I used Aeroquip industrial fittings and a 18" grease gun hose to connect to the filter housing. From the sender I used a 2027-2-2S 1/8-27 pipe to pipe 90 deg. ell, then a straight 2045-2-2S 1/8-27 pipe to pipe with a swivel nut. The swivel fitting allows me to connect to the grease gun hose with out having to spin the sender.
I mounted the gauge right in front of the transfer case lever pod. Easy to see during the day, and not too bright at night (has a dimmer wire). If I figure out the personal webspace on my ISP, I'll try to post some pics.
