I have a 1999 dodge quad cab, i just changed the lift pump & put in a raptor FrfP in the stock location and ran a 1/2 line to the fuel filter. at first I was getting 20lb at idle & around 17 psi at 60mph. I backed the psi down to 17 at idle and 14 at 60mph does that sound about right? but i notice i have a small leak at the fuel filter canister. I replaced the stock line/ Banjo at the filter with a 12mmx8JIC/oring fitting connected to a 8jic 90 degree push lock fitting then connected my fuel line. I think I may have over torqued the 12mm fitting because it had an oring on it. would it leak instead of using a o-ring and replacing it with a banjo washer? anyway my pressure where taken at the fuel filter,post filter
