All I'm saying is that we can't trust a very fast high resolution measurement, such as from a DMM or the SPA gauge, until we understand the AC component that may or may not be present on that wire. and the SPA gauge is particularly vulnerable to such noise if you depend on the peak detect feature. So we gotta understand the measured quantity before we claim measurement success.
Since learning that the sender contains an active linearization element I have been less concerned about its output impedance and more concerned about noise on the line. my own measurements with a 10K impedance DC gauge calibrated for to the sender suggests that measurements above 26,100 are not reliable. This is the data behind the conclusions in TDR issue 48, soon to appear. I used shielded twisted pair cable, separate signal and gauge grounds, and eliminated ground loops in the gauge ground by leaving the shield open at the sender.
But I have not played with the SPA pressure channels yet, except for the low side fuel pressure which I found to be very very pulsy even with 6 feet of snubbing hose. 1 second averaging works well for this, but the SPA gauge is so fast and has such granular resolution that its peak detector cannot be trusted to capture either a low or a high value for such a signal. I got peak pressure measurements into the upper 20s psi, which are probably correct, but not of interest or of value for the purpose of understanding the low pressure system. likewise, peak rail pressure measurements using the SPA gauge are suspect for the same reason, at least until we can characterize the signal we are attempting to measure.
--Doug
--Doug
