Fuel Tank Capacity??
What is the torque on the drain plug?
4WD Rear Fender Liners for 3500, Need Part #
This is a question to any of you who have had the misfortune to run out of fuel... when you filled your tank from empty, how much fuel could you get in??
I've driven around with the little fuel pump illuminated for a couple of days and still haven't been able to put 30 gallons in the tank. I'ld just like to know how much of the advertised 34. 9 gallons capacity is actually usable.
Thanks!
P. S. I'm sure that your running out of fuel was due to a mafunctioning fuel gauge... and NO fault of you own!
'01 2500 QC SLT (white/mist gray), 4x2, SWB, Cummins, Auto, 3. 54 LSD, Tow Package, 4wABS, Luverne SS Side Entry Steps, Truck Trunk, Reese 18K Classic, Tekonsha EnvoySV, Pioneer DEH-P47DH, Kenwood TM-733A. 24' SunnyBrook 5er with solar. Ram Ham: N0MEU
I haven't ran out of fuel yet . . but I have been able to get 31. 862 gals in. The gauge read a hair left of "Over E" with 672 miles highway, unloaded, flat traveling @ 65-70 mph.
That's as brave as I want to get.
FWIW
Michael
00 Driftwood 2500 ST QC ISB LB 5spd 3:54 LSD Tow & Camper Groups
my photos
[This message has been edited by madams (edited 08-15-2000). ]
I put in 33. 6 once, gauge was all the way to E,warning light had been on for at least 100 miles,it was 2:30 in the morning and my fingers were crossed.
95' 25004X4,AT,Driftwood,Banks,Warn fender flairs and running boards(Play truck)95 3500,5 speed,driftwood,Banks&phscotty,34,000 GVW apple and tractor hauler(work truck)
That beats my limit (so far). Twice I've put in 33. 1. There was a width of space between the needle and the 'E' tick. When the needle is fully on the 'E' tick, it takes about 28 ga. I often put in 25 and occasionaly put in 28.
Fest3er
Well this has to do with my 95 but its the same fuel tank as our 01 I believe. This last weekend I ran it dry, stupid fuel guage. I filled up a plastic gas tank with 5. 5 gallons of fuel. Took me 10 minutes to get it started and fueled up with 28. 5 gallons two miles away for a total of 34. 0 gallons.
Kyle
2001 Dodge Ram White 2500 Quad Cab 4x4 24 Valve Cummins 3. 54 6 Speed Manual, Alpine CDA-7863 60Wx4 CD Receiver, Cup Smoothie, 285/75/16 Dunlop Radial Rover A/T, Chrome Westin Step Bars, PowerEdge Module, 275hp RV Injectors, Straight-piped, TNT Spray-in Bedliner, Tint, DeeZee D. P. Toolbox, Bugshield, Cody GN Hitch, Tekonsha Sentinel Brake Controller
1995 Dodge Ram Black 2500 Club Cab 12 Valve Cummins 3. 54 5 Speed Manual, Ventshade Door Sill Plates, TST Kit/AFC Spring, Tekonsha Sentinel Brake Controller, EZ Drain Plug, GTS Sportguards, Tint, Wilson 3' Antenna, Cobra 75WX ST CB, Better Built D. P. Toolbox, Bugshield, Alpine 3 Disk In Dash Changer, Cup Smoothie, SS Rocker Panels, Ultimat, Combo Guage, Airlift Rear Air Bags, SS Bed Rails, Eagle Alloy 16x8 1189, Bedliner, GN/BP Hitches, 4" Downpipe/Exhaust System, Husky Floor Liners
1993 Dodge Ram Red/Grey 250 Club Cab LE 12 Valve Cummins 3. 54 4 Speed A/T, Chrome American Racing 16x8, Banks PowerPack/Quickturbo, PacBrakes, 6 Disk Kenwood CD Changer, GN/BP Hitches, Tint, DashCover, Bedliner, Boost/Pyro Guages, Alarm/Keyless Entry, Weatherguard Toolbox
2000 Exiss SS400 4 Horse GN Trailer
1996 CM Brushbuster 16' Stock GN Trailer
So far 31. 9 and the light on for about 50 miles. We will be pushing it to the limit Friday as we head off to Reno to pick up some medical supplies #ad
. The map shows 582 miles one way and I will have our 4500# travel trailer following us (I hope).
'99, 3/4, QC, SLT, 4x4, ISB, 5sp, 3. 5xlsd, tow pac, HD tcase, tow mirrors, camper pac, White over driftwood, Mist gray interior. 4-sale with less than 17,000 miles.
The most I ever pumped on a fill up was 31 gal. The low fuel warning had been on for some time. I think with the way Diesel foams you would have a hard time getting more than 35 gals in a 36 gal tank even if it were bone dry to start.
David Edwards Austin,TX
1998 2500 4X4 Reg. Cab 12V NV4500
Well, at least my truck has the record in something..... 35. 5 gallons. Bone dry to able to see fuel, not foam, in the neck. It was also kind of reddish. #ad
1996 2500 ST regular cab,long bed, 4x4, 5 speed, Rhino Liner Scotty Air, Isspro gauges
-- email address removed -- Great Lakes TDR
PURDUE STUDENT
GO
BOILERS
Dodge Makes it
Cummins Shakes it
Thanks for the info! This gives me more confidence in my truck's range... but probably won't have the same effect on my co-diver #ad
[This message has been edited by Jay (edited 08-15-2000). ]
Filled it up once with 32. 9 gal. light was on . I sweat bullets until I was able to get to a station. Much relief when i filled it and realised I had over a gallon to go... .
1996 RAM2500 4x4 5. 9 Cummins w/5sp 3. 54 rearend. 8ft Diamond plow. Scotty type k&n filter. New truck bed(crunched my other one) Hope to add 4" exhaust soon. Silencer ring reinstalled Cat fell off and ran into the woods. Can still here the turbo just fine. Truck now sounds better and runs better! New linex spray on bedliner!
I had about 500 miles on a tank and the light came on pulled in to the truck stop and it DIED. It took about a minute to get it started and pulled to the pump. Only put in 27-28 gallons.
I noticed before when I replaced the fuel sender the whole fuel pickup assembly slides in a grove which if it gets hung up on the ware spots it would run out of fuel before you are accually out.
Talked to the local Dodge Mechanics and he said if It happens sometimes you can use a rubber mallett and hit in the middle of the bottom of the tank and that should be enough to drop the pickup down.
Mac
95 Ram 2500 Auto Std Cab, Cat & Muffler Fell off, 125,000 miles.
Bombed-to-be!
Maybe Dodge should include a rubber mallet with the jack kit since they don't seem to be making an effort to improve that damn sender that so many of us have trouble with. Reminds me of my '63 Chevy,I carried a hammer in the glove box to pound on the starter motor when it hit it's dead spot. Went on for three years before the starter quit all the way!Wonder how many years you can gain beating on a Dodge fuel tank?
[This message has been edited by illflem (edited 08-15-2000). ]
While on vacation in Dallas last year, I was on my way back towards my hotel (diesel station across the road), when the baby semi sputtered and quit. I knew I was low, but boy did I feel stupid going dry. Called Roadside Assistance from the cell phone, and a guy came out with 2 gallons of #2. Poured it in, primed the fuel pump under the hood (pumped that sucker about 50 times before it caught!), and the Cummins sprang to life again. Drove the 1 mile to the station, and it took an additional 32 gallons, for a total of 34 added. Considering the floor surface area of the tank, that one remaining gallon was probably spread too thin to get picked up by the pump.
[This message has been edited by KCJackson (edited 08-16-2000). ]
I once rolled into my usual stop for fuel with the warning light on; trip odometer also confirmed that I was just about empty. With some spare cans that I carry along (total capacity = 25 gal. ), I bought 61 gallons of fuel that day. I know that I only put 25 gal. in the cans, so that leaves 36 gal. for the truck's tank. You figure out where the other gallon came from, I can't. BTW, the truck never quit running, so technically I didn't run out of fuel.
95 2500 SLT, clubcab, 2wd, longbed, a/t, 3. 54, 130K miles, "all the usual refinements"
