Well, no input from ya'll for 2 days, so this is the way I am going and why.
Because I think B## (biofuel) is only going to grow, and if it does not then the tank indicator solution will still work, and if it does the tank indicator will still work.
I am going to go with the Tempo mechanical gauge with remote reading capsule.
Why:
1. Zero electronics in the tank. No copper wires, no copper resistor board, no contact zone to wear. Strickly mechanical gears. If the statement about bio and copper, brass, bronze is right, then it is ok, if the statement is wrong, still ok.
2. No DC components except the canister to physically hold the DrawStraw top and bottom. Not reliant on DC for anything except the frame which I also made non sliding and screwed down to a fixed height.
3. No copper float, no brass attachments, no brass arms. IF (IF) the posted comments about copper / brass does create a partical problem with B## I am not going to aggravate it for myself. If they are wrong, I still have not caused myself my own problem.
4. No modifications of a Stewart Warner parts (rheostat) to mount on the DC canister. No adapters, no "engineering", no "well, that has to be good enough". No bending float arms so see if they will fit. The manufactured parts are basically unchanged (with the exception of changing the float) and will do what they are designed to do with proven technology over many years.
5. Out of the box installation (with the exception of the float).
6. The sensor is mounted outside of the tank and is designed to be done that way. IF it breaks, it can be changed without opening the tank. The sensor has 2 wires, it does not assume a ground (comes with spade lugs already connected). The DC connector has 2 wires, and puting a mating spade receiver on the OEM wires should be all that is necessary (have to solder on the parallel 2700 ohm resistor across the spade lugs so the 20 - 220 ohm DC system will work with the 35 - 240 ohm industry standard system. The OEM gauge error will read not more than 1/16 lower than actual until 1/2 tank then virtually accurate until empty).
7. Mounting flanges and seals are commercially made for fuel (including diesel) and orderable and replaceable and standard 5 screw design. Structure of the flange is 1/8" steel and made for the purpose of mounting the gauge to a fuel tank just like I am doing. A boat has at least as much (if not more so) movement than our trucks have as far as mounting security.
8. Parts can easily be ordered by the internet or any boat store and shipped from in stock. The Stewart Warner parts were suppose to take 2 weeks, then 2 weeks more, then ???.
What I ordered:
BoatFix.com:
Tempo 420040 (11 3/4" tank depth) mechanical fuel level gauge. I measured the tank at the moulded mounting place is 15" deep. We want 3" of fuel remaining when the gauge reads "empty" to insure the DrawStraw stays covered. That gives us 15" - 3" = 12" for the gauge. The closest one they make is a 11 3/4" gauge. Being a little shorter also gives us a little more fuel depth when the "Low Fuel: mil light goes off at 1/8th tank (1/8th of 24 gallons = 3 gallons more, which I think is about 3/4" more depth at that place in the verticle shape of the tank) which should give 3 3/4" fuel depth on level ground. You can adjust your own refuel level depending on your confort zone and terrain. $46. 24
Tempo 420001 remote reading capsule. This screws onto the mechanical gauge frame in place of the mechanical gauge face and is the 35 - 240 ohm rheostat that sends the variable voltage to the PCM to develop into a bus signal for the OEM gauge. $35. 82
The mechanical gauge works this way. The float is on an arm that rotates across an arc vertically. The frame end of the float arm is a gear that meshes with a gear attached to a vertical shaft inside the vertical gauge frame housing (sort of like beveled gears). At the top of the vertical frame there is a magnet attached to the vertical rotating shaft. The head of the gauge is sealed. If you use the direct reading capsule that screws onto the outside of the head the dial pointer just follows the magnet and has tank level markings on the capsule. If you use the remote reading capsule then there is a module mounted on the capsule that reads the position of the magnet mounted on the vertical shaft inside the gauge frame and translates that into variable resistance.
Stewart Warner
Installation Kit 366LP-F for tank mounting. 1 flange, 1 gasket (72030), 5 washers, 5 screws from local auto parts supplier. Came in about 3 days. I think about $20.
Float:
RobertMfg.com Poly float PF26 Cylindrical 1. 5: dia, 3. 75" length, 3. 26 oz bouyancy, . 73 oz weight. Threads on a 6/32 OR 8/32 male thread. I cut the 420040 mechanical float arm 3 3/8 " shorter, threaded 3/8" of 8/32 male threads on the aluminum arm. Screwed the float onto the arm. $2. 50@ see next comments.
I had to order 8 of them ($20 min cc order, + $15 cc handling) and I am going to use 2 (1 for OEM tank, 1 for bed aux tank) and keep 1 for a spare. So I have 5 to sell if anyone goes this route ($2. 50@ + shipping).
So there you have it, my approach. I should have it installed in 2 weeks.
Bob Weis
Note: Talking with Tom (parts guy) about the copper, brass potential problem he commented "can you imagine how many stationary & agricultural diesels there out there with copper fuel tank lines, or butyl or nitryl O rings in the fuel system. This could be a really huge problem to going biodiesel"
Why:
What I ordered:
BoatFix.com:
Stewart Warner
Float:
Bob Weis
