2nd Gen Non-Engine/Transmission Fuel Tank Module P/N 4897668AF
JTitone
I've recently posted a thread here about a fuel leak I have. Unfortunately it's not the result of a loose fitting but the metal tubes where the fuel lines connect have rusted through. The dealer indicates that whole Fuel Tank Module needs to be replaced to the tune of $475 for the part only. Another approx $500 for labor. I have 2 questions.
1. Are there other sources where Fuel Tank Modules can be purchased new for less $$$.
2. If I replace this module would it be worthwhile to also install a large draw straw.
Jim T.
1998. 5 24V, SLT, ext cab, 2 wd, fass DDRP, MBRP exhaust, Isspro Mech fuel pressure gauge, linux bed
On Rockauto.com $310 before shipping and before TDR discount (if discount code still works)
They list it under Fuel/Air..... Fuel Pump Resevoir
Chris
Hi Chris. Thanks for the reply. One other question. do you know if the fuel supply/return fittings on the fuel transfer module be replaced by themselves without haveing to buy the complete module.
Jim T
That I don't know, but this same task is on my to-do list this summer, along with replumbing the entire fuel system while everything is apart. I don't have a leak so much as I have weep. The side of my tank is wet, but I never see a puddle or spot in my driveway. That and I'd like my fuel gauge to work correctly, sooner or later I'm am going to miscalculate my mileage and get caught on the side of the road. So I am watching this thread closely.
I did pick up a module on ebay for 50. 00 Remember there was alot of these intank pump conversions done so there are some late model modules out there.
I have the top half of a module if you want it. It appears that the two fuel lines can be removed. Pay shipping.
Hello GAmes. Thanks for the reply. How do you want to work this?
Jim T.
1998. 5 24v, SLT, ext cab, 2wd, Fass DDRP, MBRP S/S exhaust, Isspro Mech Fuel pressure gauge, Linux bed.
