My original sender was replaced shortly after it quit giving reliable readings, at about 117K miles. I didn't know about the repairs that CJ Johansson and Huey Conway imagineered, so I bought one from the dealer, dropped the tank, and installed the new sender. I did notice some gouges that were worn into the 2 slide brackets, but left them alone.
Now at 235K miles, the sender is again acting up. I kept the original one, so I think that I'll try fixing it with Huey's method. I'm also going to try to secure the floating module at the bottom so it doesn't float up and down with the level in the tank. Will that keep the guage reading at "full" for a longer time? I guess if it does, then the bottom half of the tank should read just as it always has.
I've noticed that the black float at the end of the lever arm was worn away some. The hard, shiny outside "skin" on the float is what has worn away. It leaves the "powdery" inside susceptable to more wear and fuel soaking I guess. That would probably make it sink down into the fuel a little. Any ideas for a fix for the worn float? Do you think that any kind of cork or closed-cell foam would work? Can you believe that I'm being this cheap?!?
