Hey everybody! Hope you all are doing well and prepared, or at least preparing to prepare, for the upcoming holiday.
So temperatures reached 48F today and although a bit breezy I figured I'd do as DavidC suggested = cycle connector plug back by firewall (Driver side, high sort of by valve cover) it's the one with the white lever release. Before doing anything I disconnect both battery pos & neg leads and let rest for 10 minutes. Also, since I was there, I decided to do the other one that's close to it, as well as the one on the VP and the 3 on the PCM (behind air filter) and the ECM (side of block). All the pins/blades and holes/slots for them looked super clean (years and years ago I cleaned them with electronic connector spray clean and applied dielectric grease to the holes/slots) as I inspected them with a flash light and mirror. Once again, since I was there, I reapplied dielectric grease into the plug end with holes/slots, after reconnecting all plugs I then connected batteries back up. Turn the key, wait to start light out, fired right up. Let it sit idling for about 10 minutes while I locked the house up and hopped in, placed in "R" and all seemed fine. Went for a little ride to shake down a bit and bring up to operating temps = beer run. Left it idling while inside, probably at least 10 minutes, for some reason there was a line at like 3:30??? Anyway, I load the beer, hop in and put it in "D" it just died, WTF!!! Of course, since before it just died, all seemed well I was looking forward to having a celebratory adult beverage and didn't think to record a video - D'Oh! however the link below is after getting home, sitting in "N" for about 15-20 seconds and then (foot on brake) put in "R" to back into driveway. This is what it does "if" it doesn't decide to stall, oh I had the Edge Comp turned "off". Sorry about cursing and I didn't touch the go pedal as I was hoping it would stall.
https://youtu.be/cV3PT8ki9Vc
Another item worthy of mention, about a week ago I visited a shipmate of mine and he coerced me to bring my truck so his son-in-law (has a 2017 Ram gasser, nice truck) could go for a ride to see how well it runs. Well with the comp on kill, 5/5, from a dead stop I break-launched at about 10# boost and she took off like a scaled dog. Odd thing as she hit 3rd and rpms started to climb it seemed as if it was stumbling "again". Now, I say again because it was doing this before the refreshed injectors when cruising on the highway at say 70-75 and I would floor it to pass or just give a little exercise and as the rpms began rising (say about 90 +/-) it began stumbling (way, way worse than it did when my buddy and his son-in-law took a ride) almost like a gasser with a plug that fouled or ignition/fuel situation. Now, keep in mind, although it did this stumble whatever before the refreshed sticks it never, really never, stalled, started with a rump, rump, rump and I'd have to hit the fuel to smooth it out and/or the idle never fluctuated when going from "N" to any gear = it only started this BS immediately after installing the refreshed sticks. Let's not forget that (hope I mentioned this before???) it doesn't "always" do this = rump, rump at start up after a day or cold soak, or stall, or idle greatly fluctuate when going into gear from "N" or "P".
It just seems to "do it" whenever it wants with no rhyme or reason. I'm really lost on this one...
So, any ideas?
