kernen said:I notice when you shift from 4th to 5th most of the time a slight edge or catching a corner of a gear Like the synchos not quite right. Head tech at my dealership said probably that was the case and it might go away after more break in time. 10400 miles on odometer. purchased the vehicle 06 Mega SLT 3. 73, 4x4 Dec 1-05. Any of you have that issue w G56?
I'm one of those 5th missed user, dealer gave a good bill of health. It's a lot better at 20000steved said:No, there are others that don't like the "notchy" and stiff shifting of the NV5600 (the reason for the notable 5th gear miss)... and they are noisy... I don't mind the noise, but it could shift better... hey really SUCK when it is cold out until they warm up
steved
dgarcia said:Gear Vendor makes a great unit that bolts onto the back of the trans, it gives it another over drive gear. You can also split the gears.
But be careful, DC will void (or try to) your warranty if they find out you installed one of the units. IT will drop the RPM's about 500 RPM's when the unit is engaged.
Heres there phone number 800-999-9555, you can talk to Mike or Jordan. They are both good guys, or go to there web site www.gearvendors.com.
David
kowaliga said:I too, would like to know where the primary and secondary fill ports are on the G56. Where is its fluid level checked ? Does the shifter boot require removal to finish filling it? I've tried to e-mail MAGAL/EATON for this info, but no luck. Thanks for any info.
