AH64ID
Sounds good. The one I am running now will but a couple others I have tried would surge under my 7k load at 70-75 depending on tires I run 35 or 37s. With my set up it takes very little pedal and gets great mileage. In direct at 2500 I can see the fuel gauge drop on a long grade
How fast do you tow?? I could do the math, but OD, 2000 rpms, and 37s is FAST!
What is your boost:drive pressure like at 2500? Just purely looking at the load I burn about 20-25% less fuel in 5th at 2500 and 60, than 6th at 2000 and 67. If 6th would take 100% load dropping 6 mph and doing 2500 only takes 75-80% load generally.
So is this turbo a good choice for someone like myself, with only a Smarty Jr set to #3 and no other fueling? (Maybe some 50 HP sticks someday but thats it)
Scott
The 03 is a little lower rated, but that is all the fuel I push thru it. It's mainly a turbine upgrade, with a slight increase in compressor flow and decent increase in compressor efficiency.
