Gauge installation
Discrepancy on new truck ordered, what to do?
engine hiccups at high speeds
Just got VDO Pyrometer and Boost gauges for my 2001. 5... . Now I need any help/pointers that you all can share. I do know I will be mounting the pyro pre-turbo, should I remove the turbo so that I can get all the shavings out (or will a magnet do the jog)? If I do remove the turbo will I need a new gasket where it bolts to the exhaust manifold? Also where is the best spot to drill for the sensor?
As for the boost gauge it looks like I can use the boost preesure port for this install. Will I need any special fittings for this? Also which power source for the backlighting on the gauges works best? I do want the ability to dim the lights. If any of you have any pictures they would be very much appreciated...
Thanks for your input,
Doug S.
Jetpilot,
The pre/post turbo install location borders on a religous issue. Search the forums and make a decision.
You will need a way to get from 3/4" NPT female to 1/8" NPT female to install your boost line if you are going to use the MAP sensor location. I found a 3/4" to 1/8" brass bushing at a local supply house. Some guys use 2 bushings and step it down.
Here is a good link for install instructions.
- http://www.tstproducts.com/gauge_install.html
Good Luck,
Dave D
2001. 5 QC, LB, 4x4, Auto, 3. 54, Everything but Leather, Bright Silver Metallic, ARE K Series, Diprocal EGT, Boost and Autometer transmission Temp(sensor in the line) in an Autometer Dash Pod, ,Westin CPS Platinum Step Bars - Black on Stainless
If you drill with the engine idleing, the shavings will stay out of the hole.
BTW, what do you fly?
1999 2500 4x4, auto, 3. 54 LS, HD241, Quad cab SLT, Blk Sport Pkg, 16x8 Eagles, 285 Bridgestone AT, Amsoil, 80/100w lights, Valentine One, DTT TC/vb, DD2's, DD TTPM, Isspro gauges.
1992 SC400
1978 Mooney 201 IFR
Ijust installed mine the other day. What I did was loosen the turbo bolts and put a piece of cardboard between the manifold and turbo. When I was done I cranked the engine over a couple of times to blow the shavings out before I tightened the turbo back up.
The boost will go where the plug is behind the fuel filter and before the map sensor.
Hope this helped, Scott
'01 3500 qc 5sp, 4x4 white w/ green graphics dark tint, flaps,K&N 0880 and pre filter,auto meter ultra lite boost & egt in 3 guage pillar, tonneau,painless, Uniden Grant LT w/3' glass K-40,aux. back up lights,
'91 Regal 260 at Dale Hollow
Jetpilot, just sent you an e-mail. Should help.
Scott W.
White 2001. 5 3500 ETH/DEE 4X4 Quad cab SLT,tow package and camper prep,Husky liners front and rear,DiPricol pyro,boost and oil temp gauges,Edge EZ,Psychotty air,Bully Dog stage III injectors,ATS 3 piece manifold,HX40 turbo,4" BD exhaust,4" BD E-brake,McLeod clutch,Mallory 4150 lift pump,Mag-Hytec rear,Mopar tonneau,Lund bug shield,PM tractor utility back up lights,Penda bed mat and blow by bottle is bye bye !!! I love the smell of diesel in the morning, it reminds me of... . VICTORY !!!
<A HREF="http://albums.photopoint.com/j/AlbumIndex?u=1231655&a=9089608" TARGET=_blank><font color=red>My Truck</font></A>
<A HREF="http://albums.photopoint.com/j/AlbumIndex?u=1231655&a=9089604" TARGET=_blank><font color=red>THE SAINTS</font></A>
Does the trick of drilling with the engine running really work? That would sure make me feel better about not taking the turbo off.
The cardboard idea is a good one too, it sure beats removing the turbo all togehter.
I have yet to install my gauges also, they've been on the bench for a while now. If you guys could email me the tips also I would appreciate it.
Jetpilot #ad
o it right,remove the turbo. Would you want NordWurst wrenchies to run drill shavings thru your A320 turbines?You need a new turbo mt. gasket and oil drain gasket.
keep em flying. .
