I want to mount a set of gauges in my truck- boost, pyro, F/P, trans. temp, oil pressure, and air pressure.
My dad has pillar mounted gauges, and they look great until you almost hit a pedestrian(or small car) a few times from the blind spot. :--)
Is there a brand of pillar mount that doesn't stick out much? What I'd REALLY like to have is a set of mounts that sit about halfway between the edge of the dash and the defrost vent. It is just enough out of view that it will only block the view of the hood, but will still allow a quick check of the gauges. I'm a little concerned about the effect of hitting your head on those pillar mounts in a wreck(I witnessed a head on collision a few days ago, both trucks were doing over 50, neither hit their brakes, its a miracle noone died, but they were badly banged up. ) The pillar mounts also have an obnoxious glow at night, that close to your direct eyeline.
I've seen the rods pods in the newer trucks, and like the looks, but haven't seen those available for the older style dash. I have a friend that works with plastics for a hobby, he's told me how to make a vacuum form, so if there is nothing available I'll try making a few of my own(my brother has a 96 as well). I could also use some fiberglass to make a gauge set on the bezel, but that is a LOT of work, and I'd like the mounts further forward than that.
Anyone have any ideas?
