Gauge(s) Question
saw Mega Cab 3500 drw
Heavy vibrations at idle
Im alittle confused here, :confused: I have a auto meter cataloge here
and im planning to buy a gauge set-up for my 06! Im looking
at the Phantom gauges and would like to go with Fuel Pressure
boost, and egt, my question is, What type of gauge (mechanical
or electrical) do i need for each one? The cobolt gauges i can
get all three electrical , and the phantoms it show fuel and pyro
as electrical and boost to match as mechanical! SO what do i
need to go with on each one?
Mark Craig, I am contemplating ordering the AutoMeter Phantom Series electrical oil pressure and oil temperature gauges for my '03. Where do you guys recommend mounting the senders for these gauges. I was going to use a brass "T" fitting on the top of the oil filter unless there is a better location. I had heard there was a oil port on the left side of the block above the ECM. Not to sound lazy but the top of the oil filter is easily accessible. Any thoughts from your folks perspective? Dave Hess
Thanks for the reply Mark, I really like the phantom gauges and will go with them! Mark with the pyro it being electric,will i have to tap into the manifold or where dose it read temp?
there is a pair of M10x1. 0 o-ring seal ports on the left side of the engine. one is above the ecm, and one is right behind/below the cp3 pump. . with a M10x1. 0 to 1/8" npt adapter you could mount an electrical sending unit right there, but it might be a very tight fit. better maybe would be to remote mount the sending unit with the same adapter and a piece of grease gun hose [18" or so] or use a M10x1. 0 to -4 jic adapter and use a premade hydraulic hose, or make one up your self [jic fittings = AN fittings]
