Installed new autometer gauges yesterday and it looks like I have A bad lift pump. 10-11psi at idle, 9psi cruising at 65mph and 3-5psi at wot. I have an edge ez and DD1's, what do you guys think? I have the fuel line attached to the fitting on top of the fuel filter canister and its attached to the one closest to you and kind of to the left if your looking straight at it from the front. Is this the right one? Also I'm seeing 5 pounds of boost while cruising at 65 and a max of 25psi if I get on it pretty hard, does this sound alright? EGT's are running about 800 while cruising. Thanks...
B. Postel 99' Ram
B. Postel 99' Ram
