There are a bunch of options for gear driven air compressors on our cummins engines. Someone mentioned the compressor interfering with the motor mount. I do not know if it will or not, but they seem to fit fine on the trucks I have been researching this topic from. I just purchased mine, so I will see how it does. These are pretty cheap, and rebuild kits are very reasonable. The Hydraulic pumps you can use now are serious stuff to power all of our Hydraulic goodies. Remember that the air compressor spins at the same as crankshaft rpm.
All these air compressors have Coolant circulating to cool them. So some plumbing is required. All can be Supercharged by the turbo for increased performance.
All the manuals are available on the Bendix Website
http://www.bendix.com. Note there are two different spots for two different manuals, each with different information in them on the website.
Here:
http://www.bendix.com/en-us/service/library/Pages/Catalog.aspx and here:
http://www.bendix.com/en-us/service/library/Pages/SDSheets.aspx.
Also good info here:
Air Brake Catalog
Where it mounts: in the spot where your vacuum pump and Saginaw p132 power steering pump mount. Make sure you buy a Cummins Air Compressor for a 5. 9. The front flange will be part of the main case. It will look like the SAE mount that came off you vacuum pump. Dont buy the Round Cummins compressor, as those are for the HUGE engines.
The two main types: Through shaft and non-though shaft. What you want are the through shaft compressors, unless you don't want to mount something(power steering pump) on the back side of the compressor. Some of the compressors just have a block-off plate you can remove to bolt a steering pump to it. They also make a Saginaw p132 power steering pump without the compressor to mount to our engines if you didn't know.
Lets start with Bendix brand compressors:
**NOTE, These are general pictures, the mounts in the drawings are not all correct for out engines**
Bendix 2150 - Most common on ebay. most have an SAE "A" Mount on the backside for bolting a SAE "A" mounted hydraulic pump. Very common are the 2150's of the f-600's and f-700's with a ZF Pump Attached. PM for more info on the ZF pump if you have one.
Heres one off a military truck.
Here is the most common f600/f700 combo.
The Bendix Tu-Flo 400 - I don't know much about this unit as I haven't downloaded the manual on it yet. I assume it is the same as the others, with less displacement.
The Bendix Tu-Flo 500 - This is one of the largest cfm rating you can get. It is a two cylinder compressor. Harder to find.
The Bendix Tu-Flo 501 - This is a two piece version of the 501. More then that I do not know. I have yet to put my hands on a 500 or a 501. The last one I bid on the seller had a very high reserve, and I didnt get it.
