Engine/Transmission (1994 - 1998) Gear Swap
2nd Gen Non-Engine/Transmission Brake&clutch pedals fell down
Engine/Transmission (1994 - 1998) Pictures of my overhaul
The carrier is the same on the 3. 54,s and the 4. 10,s , be sure to get an installation kit with your gearset as the pinion depth shim/slinger on factory gearsets are a custom thickness. you'll have to do the math and build a shim stack out of the kit, also 3. 55 and 3. 54 gearsets are available for that axle, either will work just fine
The with the front Dana 60 you will be all set. Unfortunately with the rear Dana 80 the 3. 54's and 4. 10 require different carriers.
