I recently was jump starting a friend's truck whose batteries went dead in the cold. He crossed the jumper cables and arked the crap out of my driver's side positive battery cable, the contact is poor now and I think my truck got screwed up somehow. The battery was bubbling really loud and smoking a bit. There was a red wire the got arked right off the terminal, apparently the truck won't run for long without it, so I used some wire and wrapped it back around the battery terminal to get the truck home. I attached another end to the wire that got arked and tried to tighten the positive battery wire to the battery post, but it won't tighten up enough to make good contact anymore. So now I am sure I need new battery and positive battery cable, but I am wondering if there is something wrong with the truck now!
I scanned the truck with smarty soon as I got home and got a P1698 code that says this:
P1698 - NO CCD/J1850 MESSAGE FROM TCM/PCM
Now does this mean my computer is screwed or the TCM/PCM is not getting enough voltage or something? The truck runs fine when you start it up, but after 20 seconds to a minute it loses itself and slowly stumbles worse and worse until the truck's RPM's slow down enough for it to die. Soon as you hit the throttle it stumbles a cuts out, but if you blip the throttle you can at least drive a short distance. After the truck dies, you can wait a minute and it fires right up like nothing happened for another 10 to 20 seconds.
