Good news!! I spent the weekend working on the truck..... it was fun. I relocated my pyrometer thermocouple to the pre-turbo location, I was always a little nervous of the error factor in running the thermocouple post turbo. And... ..... I installed my factory tach (been waiting two years to install) onto the steering column... I fabricated a bracket for the install, works great but covers up the high beam and the lower quarter of the petro gauge, I can live with it. I figure that I'll get flashed
if the lights are too bright.
Enough of the I TRIED TO BY-PASS THE CUSSING FILTER chat... ... . here's my questions---
1-- when hooking up the lighting power wire for my boost gage, should the wire go directly to the dimmer screw of the headlight switch or is there a better spot to attach the gauge bulb wire too???
2-- when the truck is loaded, I've been driving the power curve by EGT level and boost gauge, dropping a gear when the EGT got to high or the motor wasn't making any boost... ... . now that I have a tach and can judge the torque curve by RPM, at what RPM will I make max torque and it's non-productive to over rev the motor?? I'm thinking that the torque curve has changed due to modifications I made, but I thought max torque (stock) was about 1800 rpm. I could be wrong on the rpm for torque... ... . I couldn't find a chart.
thanks again for the help, Rich
