by the way doesn't Atwood outsource to China?
Mine was made in USA, 'course that was 10yrs and 150k miles ago...
the B&W and most box hitches are TDC Axle . . .
B&W makes a good hitch for personal Use... If you do HH. . or commercial the B&W and most box hitches are TDC Axle . . IMO it should be 4" ahead of TDC... Also the B&W and most box GNs are to light. . I posted awhile back on 2 deaths BC of the hitch failure after turnover crash. Alll My GNs are Atwood custom build by A&R Welding in Ham lake MN (Al). . the hitch sits on 1" steel.
Do you have LB or SB. . If You don't mind. . measure form rear pickup bed to TDC ball. I have customer that wants Banks Dual Exhaust and the last one I sold the customer had B&W ... complained that the hitch was hitting the exhaust ,that was back in 06... Maybe B&W has push it ahead some...
I had one installed in my '09 (also got the companion) when I bought my 39' toyhauler and am looking to get rid of the goose hitch in the '92 and install another one for the quality and flexibility
Oh... And It's made in the states!!!
Edit: Oops!... Been busy for a while and just now got around to submitting my post. :-laf Glad to see that you have made a choice. You'll be happy for many years to come by choosing the B&W!!!
Long bed is a measured and centered 4" hole 47. 5" up from back of bed. Short bed is 45. 5" from back.
I've installed an unknown number of these, and they have all worked very well, both for customers and myself. On my personal trucks and my ranch trucks, I haul everything from a 40' tandem 12k axled flatdeck with pipe, wire, t-posts, and tractors, to a single axle 20' with an 8k with two/three horses in it. Loads range from 1200 to 35,000lbs, well over what should be hauled on a dually truck. My "light" trailers have two 8 lug 8k Dexter axles, and I drag cattle, horses, tractors, trucks, etc all over the countryside, on and off road. I've had to unload my tractor to pull myself out, and I've drug wires off the back of the trailer from draggin it across ditches, trees, and whatever else I have to get over. I don't know what you're doing to yours, but other than a little rattle in mine, I really think the B&Ws have held up well. Anything will break if you jack knife it. I've seen fifth wheel semi trucks break the fifth wheel completely off the frame from hitting the ditch. And the next time you look at a fold down knob, try the Wallace Forge. They're even heavier than the Atwood with a fully forged and solid side support piece, a larger center ball pin, and a lock pin that keeps the ball up, even if the side bar is up.
Also, look for the Remov-a-ball series of hitches, with a 2. 25 shank, and I can't remember the name, but there's also a company making a 35k knob with a 2. 5" round shank that sits in a 3/8" round sleeve that's welded down in the plate, with a retaining bolt or pin that allows it to swivel, and still be removed. Those are about the heaviest you can build in the 2 5/16" series.
If you're looking, the B & W Model 1300R is used for the 93 and earlier Dodges. But it requires side plates be made for it, as it doesn't have ones like the 1310 or 1306 models. It's installation instructions and illustration: http://www.turnoverball.com/sites/default/files/documents/1300r_04_19_2011_letter.pdf
its already installed. dad-gum, take it easy on me. point taken. i got it.
