JStieger said:On mine I just reused the stock intercooler hose as I didn't have the means to fab a new pipe. It was a bit of a stretch though! Since I reused the stock pipe, I also had to rotate the intercooler pipe about 180*and grind some clearance on some metal brackets on the corner of the battery tray.
Just in case for future use I bought some silicone hose and had the supplier custom make one end 3" and the other 2. 75" (intercooler pipe end). It was only about $15-20 to have this custom piece made. Lastly as an addition to wcounts recommendations, if you do use new silicone hose, double-check on the clamp size as the high-pressure rated hose is pretty thick walled. Don't ask me how I know this after I had everything apart... (the 3" clamps I bought were a hair too small)
So to use my stock intercooler pipe, I will need to rotate 180*, and then I will also need to manhandle the too-small boot onto the 3 inch compressor outlet, right? So I better have a 3 inch clamp for the compressor outlet eblow, Certainly the the factory one will not work, right?
