Grease won't go in zero fitting???
Shift Indicator
SS Brake lines
Right side outer most joint (connected to hub) - I was giving all the zerks a few strokes of grease and the joint referenced wouldn't take any. I removed the zerk fitting, stuck it into the end of the gun and it is clear. Just because I installed a new zerk fitting - same thing. The joint is free = can move by hand clockwise and counter clockwise, it doesn't have any play up or downside to side, just can seem to get any grease in it.
Ideas?
Thanks
Do you have one of those grease fitting um-blockers? I had a few do this do to grease hardening in the fixture. With this tool, shooting a shot of oil into it will loosen the grease up. Saves the time of disassembly and cleaning of the fixture. Worth a try and another tool for the toolbox! Good luck!
Note: removed fitting, put it in gun and grease flowed. Installed new fitting in joint and still no flow.
Games, think it's called the drag link. Longest rod/joint attached to right side hub (8800 gvw 4x4).
Thanks for ideas.
