2nd Gen Non-Engine/Transmission Great ball joint tool!
Engine/Transmission (1994 - 1998) Saw this on another forum...
Engine/Transmission (1994 - 1998) Boost issues? Turning it down?
I recently had to replace my left front caliper, hose, rotor, etc. While it was up, I notice the bottom ball joint was loose. Surprised me because I typically get 100,000+ out of these joints and it only has 60,000ish. As it turned out, It wasn't the joint but rather the retaining nut was loose, which caused the ball joint's tapered stud into the C-knuckle to flop around.. what to do?
I figured out that the nut is 33mm, found this tool and order one off Ebay (Kent-Moore J-44664). The tool is made for a Dana rear steer truck axle.. but bam! perfect fit, slips right under the u-joint and on the nut. Once hooked to a breaker bar it pulled the ball joint stud up very tight. All slop gone!
VERY NICE, 5 min fix without taking the entire front hub, spindle assembly apart to access that nut. Best $30 bucks I have spent in years!!! I'm fixed up now and have the right tool for installing the next set of ball joints when the time comes.
