well that is real good to know. if i check the rear diff. fluid, would i see any signs of it being bad (metal shavings, real dirty and/or old fluid?)???? is it possible to have the rear end checked by a shop for realativly cheap?
also, how did you determine it was the rear end and not the clutch?
did rebuilding the rearend totally solve the problem?
when i try to start with my wheels turned at all it make the problem much worse. if i give it just a little throttle and feather the clutch a bit i can start it pretty smooth, unless im on a steep grade or tight turn. but from a dead stop on flat ground it will shudder when i let the clutch out unless i feather the throttle/clutch.
how safe is it to drive the truck in this condition????
am i ok to keep driving it?
