Group Purchase on Fluidampr Harmonic Balancers
programmers
DTT Trans Enhancer
Another question:
Torque value on the retaining bolts is 30 Ft Lbs + an additional 60 degrees according to Fluidampr.
What does " an additional 60 degees" mean?
HEMI®Dart said:
Another question:
Like head studs, to get an accurate torque value that is not thrown off my thread friction, torque the bolts to 30 first, then go back and twist them an additional 60 degrees (use a protractor to get somewhat an accurate measurement). Figure 60 degrees is 1/6 of a full turn.
If the bolt breaks , you went too far.
If the balancer falls off on the freeway, you didn't go far enough.
Thanks hasselbach
My Service manual says 92 Ft Lbs and so does the Dowel Pin Fix instructions @ TST.
I think I'll go with that. :confused:
I used the factory torque settings for my "fluidampr".
In Horschel's directions it even says to use the factory torque settings for the bolts.
But they added a supplement to help Diesel owners since they probably figured we didn't know what to torque these things to.
I used 165NM.
I used 165NM.
Did it quiet down your transmission noise?
Problems w/ a Fluidampr on a '94
Got Fluidampr P/N 960311
I have a 175 HP truck. I have the "big" 215 HP Damper to start with.
I moved the engine speed sensor to its max travel away from the damper, but it still needs to go another ¼"+.
Can I get a shorter sensor, or did I do something wrong? :confused:
Second picture is the pickup set @ . 050 on the 9-3/8" OEM damper.
Doug or anybody?
Thinking of getting one for my 160 hp 92 but the oem is about 8 1/2" diameter. I would have the same problem as you HEMI DART.
Kurt
Bill.
Looks like I will run into the same problem.
And mine is the 8 1/4" factory damper.
Hope there is an easy fix for this.
BTW, time to update your signature.
Brad
This is the first I have heard/seen of this problem..... I am out of the shop today but I will make some calls and try to determine what the issue is.
Doug
I just spoke with Fluidampr and they just became aware of the issue at hand..... But in any case they are working on a solution (looks like a new mounting bracket for the sensor). I am pushing for a timeline now, I will keep everyone informed.
Doug
Wouldn't it just be easier just to space the crank away from the sensor like using thicker main bearings? :-laf
Doug, can't wait for mine, has it shipped yet?? If it quiets down the nv5600 even a tad, its gotta be a good thing.
In following this thread, I haven't noticed any replies to the question of, "Will this be of any help to automatics" that have been modded? (EG: T/C's)
Doug
Any more news on this? I just tried to install one on my engine and was VERY disappointed that it did not fit. Did they ever test fit these things or what?
I spoke with them today and they are now telling me 3 weeks..... I too share your frustration on this issue. We will do whatever you want to fix the issue, refund, wait on new damper, etc. Just let us know what you prefer and again I appologize for the fit issue.
Doug Smith
Doug Smith
I bought the damper from another business, we will see what they say. I will likely just keep it and see how good Fluidampr's fix is. It looks like a very quality product otherwise. A warning to other 12 valvers out there, you might want to hold off on buying one of these units until Fluidampr fixes the tach sensor mounting issue. ;)
