Yesterday I had a big day of getting caught up on some work on my truck.
First I pulled the starter and replaced the contacts with the 24 volt ones from Larry's. The old ones were hardly worn at all though - figured I'd put the new ones in and save the old ones since it was off.
Then I replaced the fuel lines with the West Marine lines as recommended - what a job! Yes it is a bad job as everyone says, but well worth it. My old lines were all full of cracks. Hardest part was getting the old ones off - had to pull the starter, move the front driveshaft over and pull the master cylinder over to the side. Still very difficult. Putting the new lines on was much easier than getting the old ones off. I also checked the screen filter - it was clean.
I decided to pull the AFC cover off and look inside since I never looked at the plate before. Mine has a Bosch #2 3694 plate - anyone know how it corresponds to the other aftermarket plates? Anyway, it and the AFC cover were in the middle, so I moved them all the way forward. Did not change the star wheel.
Then I installed the 3000 rpm governor spring kit. Not a bad job. Went through the side and followed the directions. Had to lower my idle speed a little afterwards.
Results seem good with more low end power and faster acceleration. Rpms go right up. I've only driven it in the dark so can't see any smoke yet, but will see today.
Will I need to adjust the star wheel or can I move the AFC cover foward without adjusting it? Any suggestions please.
Thanks,
Blake
Thanks,
Blake
