Guage Swapping
Hadley Air Horn Kit
Which Dana do I have?
I have the Banks guages on the A pillar and am adding some new additional guages. I would like them all to match so I'm considering changing out the Banks guages. I'm pretty sure I am going with Isspro. Do I have to change all of the senders or can I use what is already there??
Kev
Don't know which Banks gauges you have. The Isspro pyromiter is about $125 from DIS Lubbock and includes the thermo couple. The boost gauge uses tubing. So no big deal. Do not mix thermo couple and pyromiter. If you have a transmission temp gauge you will need to replace the sending unit. Again no big deal.
Have fun. You will like the Isspro's
I have the Dynafact guages- I believe they are electronic, except the boost which I know uses tubing. I can use the same wires and just change the thermalcouplers right??
Kev
