guage wiring
Sport Headlight Conversion
shocks revisited
Ok, I need some help here... I was wiring in my guages, got to the lights, and ran the wire to the bottom leg of fuse#13, as I believe I read that here on TDR. The lights on the guages were on, but did not work with the switch. We located a wire under the dash that allowed the lighting to come on and off with the light switch, so hooked in there. What I would really like is to splice into the wiring to allow dimming, but I hate to pull my dash apart to get at the dimmer switch. Anybody out there know how I can locate a wire(color coded, etc) that comes from the dimming switch, and I can just splice into it under the dash?
Thanks,
Rob Hanson
1999 3500 SLT QC 4X4 Cummins
Flame Red, Rhino, 6 spd, 4. 10LSD, FX Running Boards, Cobra CB, Stinger Bug Shields, Mag-Hytec rear cover, Cummins E-Brake, Torklift Super Hitch, BD 4" exhaust, Blue Box, Halogen Backup Lights, 4"rear mounted tractor lights, Autometer SportComp Boost and EGT Guages,
Member of BOMB! (WW NW Chapter)
I'd rather be... .
Cummin than Strokin.
Rob, I believe that it is fuse F5
Mike Clay
98. 5 24V,QC,2500,4x4 SLT K&N filter Scotty Style, DD True Torque Injectors, smittybilt step rails, camper package, hd tow pkg, chrome rocker panels,lund lighted visor, emerald green. Towing a 30' Gulf Stream Sea Hawk 5th Wheel triple slide.
Rob,
According to the tst website gauge installation instructions:
"Attach one of the two black wires for the instrument bulb to a good metal ground and attach the other black wire to the lower side of the dash illum 5A fuse, fuse 13 in the block. Using this fuse as a power source dims the gauge lamp when the instrument panel is dimmed. Connecting to the lower side of the fuse protects the gauge lamp circuit with the vehicle 5A fuse"
This is the power source I used, and it comes on and dims with the dash.
Craig
On my '99 QC 3500 , it is the "5 amp fuse" , tan in color , and is numbered # 5 , use the bottom leg of the fuse. # 13 is for my power door locks. It is on the top of the fuse block , and in the middle. It is also the only 5 amp fuse I see.
Hope this helps.
99 3500 QC, white, 5sp, 3. 55lsd, isspro EGT & boost, stock, 26,200 miles 12-13-99- -EX phord owner
15-16. 5 MPG hwy ,14-15 city , 10-12 with 4,000lb TT
Rob,
I have a better way than tapping onto the leg of fuse #5. The dimming circiut is an orange wire, and is easily found in a small junction under the dash. I switched mine over the other day, and it took all of 2 minutes to do. No special parts or fuse leg taps needed. I's be glad to show you what to do! #ad
BOMBNESS
Evan A. Beck
98. 5 2500, 4x2, RC, ISB, A/T, SLT, 3. 54 LSD, Trailer tow, Aux. suspension, Forest Green/Driftwood, 52,002 miles, 12/21/99
4" Exhaust split into duals, with 4" x 20" chrome tips one on each side after the wheels, Jacobs E-Brake, K&N Filter (Scotty style), Auto-Meter Ultra Lite boost & pyro, turbo silencer ring removed, OEM foglamps, OEM roof marker lights, OEM 1-ton tailgate marker lamps, Sylvania Cool Blue® 9004 headlamp bulbs, Husky diamond plate toolbox, Line-X spray-in bedliner, plus other cosmetic modifications
"I'd Rather be RAMMIN' than STROKIN'"
"Journeyman B. O. M. B. Member"
Page In The Works
I tapped into the light that runs to the ashtray. Works great.
John
1999 Dodge Ram 3500 Quad Cab 5 spd; 4:10 LSD rear; Mag-Hytec diff. cover; US Gear EGT and Boost gauges.
Rammin' and Runnin', but not stepping on the rails
