Hey guys, I see alot of New guys asking common questions so I dug this out of my archives, originally written in 2000, and updated in 2001 and last in 2005.
Some of the info is outdated but still a good read.
Enjoy.
Proper Order for Upgrading 98. 5-02 ISB Engines
By: Ted Jannetty
Jannetty Racing Enterprises Inc.
Revision 7/05
My motivation in writing this article stems from all the misconceptions I read on various message boards and from all the tech calls I take on a daily basis.
This is also a revision of the previous article based on new and improved parts and technology.
I will put in to order, performance modifications and all the how’s and why’s, so all can make educated decisions when purchasing performance parts and services.
Diesel engines have very specific needs as do other engines; I will cover the 24 valve Cummins 5. 9 ISB engine produced 98. 5 to 02 Dodge model years.
Step 1-Gauges;
EGT: or exhaust gas temperature gauge, measures exhaust gas temperatures leaving the combustion chambers.
This is the window into the tune up of your engine, it will tell you everything you need to know, if you use the knowledge I will provide.
The best place for your EGT probe is Pre Turbo, and these numbers are based on this placement.
Average temps: Stock truck
Idle – 250 to 450
Cruise no load 400 to 700
Cruise with trailer 500 to 800
Pulling hill no load 500 to 1000
Pulling hill with trailer 900 to 1250
Temperatures will vary whenever the throttle is moved or the terrain changes.
The peak number is the most important while towing, the ISB can be safely run up to 1450 for short bursts and 1350 all day long.
This number is strongly affected by modifications weather it be Air flow or Fuel delivery.
If air flow and fuel flow are increased EQUALLY, Very important words here!
We can increase power to very impressive levels with no increase in EGT or smoke.
Boost: or intake manifold pressure above atmospheric pressure created by the turbocharger.
Atmospheric pressure at sea level is 14. 7 psi this equals 0 on the boost gauge.
Boost pressure tells us how well your turbo is working, weather or not you have a boost leak, and how your waste gate is adjusted.
Average pressures: Stock truck
Idle – 0
Cruising 70 mph no trailer 5-10 psi.
Cruising 70 mph with trailer 7-15 psi.
Pulling a hill no trailer 10-20 psi
Pulling a hill with trailer 15-21 psi
Again this number will vary like EGT, with throttle position and load.
Air flow and fuel flow increases will make this gauge move much faster.
Fuel Pressure or pressure created by the electric fuel pump that carries the fuel from the tank to the filter then on to the injection pump.
This has become a very important gauge on the ISB with all the fuel pump failures that have occurred and cause drivability issues.
This gauge is not very exciting but when there is a problem it becomes very important in diagnosis, plus it can save a very expensive injection pump from failure due to lack of lubrication and cooling.
Average Pressures: Stock truck
Idle – 10-14
Cruising 8-12
Pulling a hill with trailer 8-9
Absolute minimum pressure is 8 psi; anything below that and you need either a new lift pump on a stock truck or an upgraded fuel system on a modified truck.
Transmission Temperature: or temperature of the transmission fluid that leaves the torque converter and goes on to the coolers.
Again not very exciting be very important to the life of your transmission and or torque converter.
Temp sensor placement should be in the (hot) or out cooler line of the transmission and these temps are based on this placement.
A temp sensor located in the pan is useless since all the fluid in the pan has already been through the coolers.
Average temperatures: Stock truck
Idle in neutral or park 140 to 160
Idle in gear 160 to 260 depending on how long.
Cruising 70 mph no trailer 150-170
Cruising 70 mph with trailer 160-180
Pulling hill no trailer 180-220
Pulling hill with trailer 190-280 depending on load and how long a hill, or weather you can pull the hill in lock up or not.
Temps will always be higher when out of lock up, because 90% of the heat generated in an automatic transmission is from the shearing of the fluid in the converter.
Temps will be lower when in lock up because the input shaft of your transmission is locked to the crankshaft on the engine.
Now that we have covered the gauges we will move on to what I believe to be the most important whenever you decide to increase the power of any engine
Step 2-Exhaust system; or the pipes, resonator and muffler that carry the exhaust gasses from your engine out the back of your truck and away from the passenger compartment.
Exhaust system serves two purposes on this application, carry the exhaust gasses out and make it quiet the cheapest way possible.
Therefore there are performance compromises made by the manufacturer to save money.
Bending:
There are two ways to bend pipe used in the exhaust industry, first is the best and most expensive called Mandrel bending, this bending process keeps the pipe true to size and smooth in the bends.
The second called compression bending crushes the pipe about 20% in the bends.
This being the cheapest form of bending.
The factory is now using compression bending on Dodges built after 99 model year.
All systems we offer are Mandrel bent.
Pipes:
Pipe size is in direct relation to the intended Horsepower.
2. 5 inch pipe can support 150-200 hp
3. 0 inch pipe can support 200-250 hp Dodges are 215-245
3. 5 inch pipe can support 250-350 hp
4. 0 inch pipe can support 350 450 hp
4. 5 inch pipe can support 450-550 hp
5. 0 inch pipe can support 550-650 hp
These Horsepower figures are only good on Mandrel bent tubing.
Using smaller pipe on a turbocharged Diesel limits performance and efficiency.
There are no benefits to using small pipe except cost.
You almost can’t go too big on a turbo Diesel.
We targeted 4 inch pipe because it falls in to the Horsepower range the ISB is capable of, it fits nicely, it performs as promised, and sound control is good.
Materials:
Steel, Low cost easy to work with last 18 to 42 months.
Aluminized Steel, Medium cost, easy to work with, lasts 3 times longer than steel.
Stainless Steel, High cost, hard to work with, lasts 8 times longer than steel.
We use 14 gauge/ . 090 aluminized tubing in our JRE kits.
Mufflers:
There are many different designs, the list is almost endless but the most common are;
Reverse flow- Excellent sound control but restrictive.
Chambered- Has good sound control but less restrictive.
Perforated tube- Has little sound control, Resonates bad, very low restriction.
Tuned chamber perforated tube combo- Good sound control, very low restriction.
We use the tuned chamber perforated tube design, cost more but worth every penny when driving long distances.
4” exhaust system is a must on modified ISB in the Dodge.
This is the second step in upgrading your ISB.
Benefits are:
Less back pressure
Lower EGT
Quicker Turbo spool up 0 to full Boost
Improved throttle response
Better fuel economy
More horsepower
Plus that awesome big truck sound.
Step 3-Air filtration and flow;
Oiled cotton gauze type air filters have been around for ever it seems.
They are the #1 high flow air filter in the world and are used in all forms of racing, Drag racing, Baja trucks and cars, dirt bikes, snowmobiles, watercraft.
If they didn’t filter out dirt Racers wouldn’t use them, so let’s put away that myth.
Air flow in to the turbo strongly affects response, fuel mileage and power, as well as EGT; more air flow means cooler EGT, and better performance.
The Factory filter can not support any modifications on this engine and it will be a restriction that can make EGT go too high, and limit performance.
At the absolute minimum install an oiled cotton gauze replacement air filter in the stock air box and remove the plastic tube between the fender and box.
Best would be to install an aftermarket cold air kit, that has double the filter area, and is quiet, comes with a heat shield, these have shown 14 hp over the high flow replacement in the stock air box.
Step 4-Fuel system upgrades;
Any time we do power upgrades we have to take a look at the fuel supply system, because without fuel we can’t make any power.
The factory lift pump on the 24 valve engine is barely adequate to supply a stock engine and the failure rate on these pumps is high.
Reasons for lift pump failures are attributed to the location, distance and height from the tank.
Electric fuel pumps should be no more than 3 feet from and mounted lower than the fuel supply for gravity feed.
I suggest you check your fuel pressure at idle and while driving, you should have a minimum 11psi at idle and should never fall below 8psi while driving.
If your factory lift pump fails this test, and is still under warrantee, have it replaced by the dealer.
Another area that is lacking is the fuel lines on the engine, or what is better known as the banjo bolts.
There are five total, inlet and outlet of engine mounted lift pump, inlet and outlet of fuel filter housing, and inlet of fuel injection pump.
These create a major jam in fuel flow that the lift pump has to work against.
The home solution has been to remove the banjo bolts and increase the size of the holes by drilling and carefully, deburring all the holes.
This has shown improvements in flow and reduction in stress on the pump.
The best solution so far is to replace all the fittings with aircraft type Aeroquip #6 an fittings and braided steel line.
JRE was the first to offer a kit to do so.
See Part 2
Enjoy.
By: Ted Jannetty
Revision 7/05
Step 1-Gauges;
Idle – 250 to 450
Idle – 0
Idle – 10-14
Cruising 8-12
Bending:
Pipes:
Materials:
Mufflers:
Benefits are:
Less back pressure
Lower EGT
Better fuel economy
More horsepower
See Part 2
