Gutless 600????
03 235HP,250HP,305HP Ramifier users
Turbo Problem?
The only reports I've read suggest that defueling does occur when overboost conditions are set (not high egt's), but that should only happen on a modified engine, i. e. stock engines shouldn't be able to overboost. If you had an intake and different exh/muffler maybe.
Dave
I just thought that since I am sure the egt's were high and a turbo is driven by latent exhaust heat. I was surely pulling full load on the engine and with the high elevation, temps would be high due to a lack of oxygen. I remember reading that thread recently about the high flow exhaust alone causing that dyno'd truck to defuel. I am wondering with the combination of things I had against the truck that it could do it with a stock exhaust.
Unless something has changed with the 600's, Cummins hasn't ever had an EGT probe to sense EGT, so I really doubt that the ECM is de-fueling because of that. Sounds like a handy feature though.
