H1e
I officially have no life
315's with leveling springs
Ok, the H1E has been on the bench long enough. What pump and injectors should be used to get enough fire in the hole to use this monster? The intake side seems to be the same as my H1C. The exh. side is much larger, 26 cm. Can the exh. side be downsized to work with my 5. 9. Also the center/bearing section is larger but retains the same bolt patterns as the H1C. Is ther a 14 or 16 cm housing with a 4" exhaust flange?
I know H1C housings will interchange with a HX35; maybe a H1E can interchange with an HX40? 26 cm sounds like the bottom end of a set of twins.
Daniel
I know a few years ago, they were tlaking about the H2E being quicker to spool than the HX40, this was when a 16cm housing and PW injectors were IT for the first Gens, and aHX40 was still something iffy. That said, I'd assume the H2E comparable to the HX40, with an H1E maybe being a hair bigger than the HX35?
Never heard of H1C/ H1E twins, but know several guys have run dual HX35s or something similar, so I dont see why it couldnt be done.
Daniel
