Motobeagle said:You need to search more. I've found plenty of cheaper sets
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=66475&item=7955265220&rd=1
JeepinDoug said:I'm glad to see you have a sense of humor, got a little worried after I posted thinking you might take the wrong way.
That link is for tires ONLY.
JeepinDoug said:First off... . big props to Yo Hoot, his H2 tech article is the real deal.
I wouldn't say I followed it to a tee but everything turned out perfect as I went.
I found my H2s (less tires) on eBay for $150 and the guy reamed me on the shipping, his feedback isn't looking as good as the wheels do. The H2s I got have less than a 100 miles on them, allegedly, they do look really good.
For the center cap I set a sharpie on a block and spun the cap against the sharpie to mark the cut zone, all done on a work bench. I used a 4. 5" grinder with a cut-off wheel sitting on blocks so the wheel would cut on the sharpie line. Turned on the grinder and hand turned the cap until the cap's skirt fell down (whoo-hoo).
Next I swapped the cut-off wheel for a 40 grit flapper wheel and sanded the lug nut grabbers down to fit the wheel.
This was so easy it took an hour at most.
Elite1 - Yes, your stock tires will fit fine, that's what I'm using.
EDIT - Here are some pics.
Full side.
Here you can see I'm angled out just a bit to see the rear tire, they don't stick out enough to make flares a nessecity.
VB bulliten's resizing pixilated the pics, just click the link underneath for higher rez.
JHardwick said:Has anybody found a repeatable means of balancing the wheels once the center hole is butchered?
I still don't understand. You spend $75 or more on a hole saw and tool rental when you could have a local shop give you a precision hole for probably less $$.
Elite1 said:JHardwick, Since you are a machinist, When I look for a machine shop to open up this hole, what kind of machine would be prefered? Should it be a precision grinding shop, with a certain type of machine?
Thanks, Marty
Bertram65 said:There is such a small amount of metal being removed that it would be almost impossible to have any effect on the balance of the wheels, also any difference in weight has less effect on the wheel the closer it is to the hub, so to worry about balance problems as a result of having the center hole enlarged is really a moot point.
Elite1 said:The H2's caps won't work on the rear wheels...
