Originally posted by CumminFast
You mean you are going to pay $200 for a new torque plate???? Do you have a bench grinder? Grind that *******! I think you guys are anal about these egt issues. I dont think a custom cam plate will cause you engine to "melt down. "
Neibe said:
well if it ain't in the original position you could put in the new one and have less power or be off center so the needle on the rack won't contact the shape on the plate. Or if emmissions testing is a concern you can't put it back to stock. You can't grind it I compared the original to the new one and the new one has stock added the original has a notch so you would have to weld it.
Why is this necessary??? Why does it need to be in the orginal position? too much power?
