I bought a converson kit to convert my 2001 truck to a p-pump. I talked to patty at Haisley Machine about the kit and she told me that the kit included every nut and bolt that would be needed except the P-pump and the fuel shut off solenoid. The kit ran me 1400. 00 Which i thought was fair for all the parts and hassel that it would save me in the long run. When i started to install the kit on my truck, I kept finding more and more part were missing out of the kit. Which in the beginning i was told several time that the kit had every nut and bolt. It was far from the truth. I called patty, the response that i got from Haisley was that different years of trucks need different parts. I agree with that statement to a point. But all trucks need oil feed lines and throttle cables. After putting my truck back together, i found out the they didn't move the Cam gear senors over, so i cant use my stock RPM gauge.
The parts that i got with the kits was the injector lines, intake spacer, fuel return line, front gear housing, and pump gear, 12v timing kit which you cant use on a 24 v unless use you a 12va cam gear,pump linkage and a few other nuts and bolds.
The parts that should have been included in the kit were TPS, throttle cable, banjo fitting to connect the line to the pump and a fitting to connect the line to the T block in back, the pump oil feed line, and the 90 degree oil feed fitting.
When i called Haisley Machine yesterday to talk to them about working out some compensation for the missing parts. The response the Patty gave me was that i have two options, One was to take the kit off after i have my truck fully put to gether or LIVE WITH IT. They didn't want to do anything for the kit not including all the parts like they told me in the beginning. I would have been happy to get a few dollars taking off of the price.
:-{} With dealings with Haisley Machine, I would Never buy anything from them again and i would RECOMMEND not doing any business with them. If you spend 10s of thousands of dollars with them, im sure that they might be nice to you that they were with me. My 2000. 00 is not enough for they. Thanks
