Nest question, did you phase the CP-3 correctly when it was installed?
There is a TSB on how to do it for best results.
nuts... well I can probably adjust the phase without removing the pump...
The link is to a real Ram TSB for addressing a known NVH issue
CP3 is also used on 8 cylinder engines, how does that math work out?
That is way too long, all things being equal if you are not getting fire after 2 revolutions and\or a slow 2 count you have issues somewhere. If the pump helped then you probably have worn injectors and\or PR valve.
