Hardlined Wastegate........Drill Hole????
15.34 @ 88MPH, Life is good.........
Need factory fog light switch for torque converter lockup
I just received my EZ. The instructions for the hardlined wastegate say to install the supplied plug (not included)and drill a hole in the line with the supplied #62 drill bit (not included). Has anyone else here received these items with their kit and done this installation.
Also, I have an early 2001 (rear drums) and the kit shipped is for a 1998. 5 - 2000.
Is this in fact the right one?
Im leaving tomorrow morning for Lake George to try out my new 5th wheel and would like to have this installed.
Thanks, Ron
2001 2500 SLT+ 4X4 Auto Cummins, 3. 54,Quad cab,Short Bed,Camel Leather, White Exterior, Sliding rear window, Camper Special Group, Towing Group,A. R. E cap with rear door, 29RKBS Cedar Creek 5th Wheel.
I got my EZ not to long ago and used the turnbuckle method and it is working just fine. Do a search and I'm sure you will find it. I like it because it's completely reverseable. You'll love the EZ. L. O. L
Rich
20yr Mopar Parts Manager,"June of 2000" 2001 quad cab,2wd,auto,Camper pkg,354 LSD rear axle,Raven Magnum 8' cap. Mag Hitech trans pan. Isspro gauges pyro,trans and boost Apillar mount. Amsoil air filter. No muff!EZ Edge!!!! N. R. A. member
I dont think You got the right EZ. . My Box says for 2001's, and I was asked specificly if I had a 2001 because there was a difference. HVAC????
2001 QuadCab,SWB,Auto, 4X4,4" Flowmaster Raceing Exhaust, DTT TC & VB, EZ Box, Bosch 275 Injectors, Mag-Hytech transmission pan/Dana 70, K&N, 33" BFG AT'S... ... .....
Apparrently there is a 2001 and 2001. 5. I got a 2001 which works just fine, but no plug. I used the turnbuckle method and I must say it work REAL good. Peice of cake to install. The post about it is from "zman" w/ a title "easy way to disable HY35 wastegate" or something to that effect.
