Engine/Transmission (1994 - 1998) Harmonic Balancer
2nd Gen Non-Engine/Transmission Fuel pres. guage ques.
Engine/Transmission (1998.5 - 2002) SB DD Clutch
Is the crankshaft serpentine pulley part of the harmonic balancer? My pulley has some minor crash damage that looks like it will shorten the belt's life and I need to replace it.
It's a '94. I was thinking of installing the bigger 215HP balancer, since I'm going to be bombing this engine.
If you truck is a 5 Speed, you have the 215hp balancer already.
3924435 is the Cummins # for the 215 damper. If yours is damaged, remember it is cast iron. It could break apart and take out the radiator, hood, etc. I recommend replacing it asap.
My thoughts exactly! The engine's on a stand right now and I'm taking care of everything it needs before installation - including a PDR camshaft and of course the KDP fix. I intend to leave everything else stock, for the initial start and testing, to baseline the engine and then the bombing will begin in earnest :D .
