So I bought a $1300 cummins in non running condition a while back. It needed injector tips and a lift pump. It's about as beat up as these things get. It has 379k miles on the odometer, which doesn't work.. So I found a he351w for 550 usd and installed it on my cummins. The exhaust down pipe was shortened 1.5 inches. I had to make an oil drain spacer from aluminum I had laying around. The factory oil drain bumped into the waste gate actuator (which I kept) so I pushed the drain pipe down ~3/8 of an inch into the rubber hose it connected to and fabri-cobbled a spacer using a belt sander and a band saw. Also, there was a long bolt keeping the turbo from clocking proper, so I band sawed that little bugger as well. The he351w has a smaller compressor wheel than the he351cw, it is 58mm vs 60. But the exhaust housing is 12cm vs 9cm for the he351cw. I had the 18cm exhaust housing on my old h1c. Oem oil feed fit. This is my first post, so I'm sorry if I do anything wrong
View attachment 118469 View attachment 118470 View attachment 118471 View attachment 118472 View attachment 118473 View attachment 118474 View attachment 118475 View attachment 118476 View attachment 118470 View attachment 118468 View attachment 118467
