I thought that I'd give you an update. I replaced the headlight switch from Advanced Auto twice. In both the dimmer and cargo lamp circuits either didn't work or didn't work correctly. I eventually got one from Auto Zone which seems to be a better product. Genos has a Mopar switch that may be worth the extra $30. I replaced the headlight lens with the sport conversion headlight lens from Genos. I got the conversion wiring harness from Daniel Stern. For those interested in doing the conversion, Daniel Stern makes a good quality product and seems to be around to answer questions. I now have a lot more light and hopefully solved the melting headlight switch.
As an aside I did not drop the bumper to install the headlights. I don't think it's necessary. With a little patience and manipulation, they slide right in and out without a fuss. I had more trouble and aggravation removing the grill guard after 17 years. Once it was out of the way, I had no trouble installing the lens. Additionally, the Turbo Register has an old article on this conversion. If you need to cut sheet metal to make room for the second bulb, pay attention to the pictures. You really do need to cut that much metal out. A sawsall and Dremel with a cut off wheel made short work of it.
Thanks for everyone's help and advice.
