headlight problem
Interior Lights (Delay Timing)
05 won't turn off
My passenger side low beam light is out. Not the bulb. Not any fuse. Works on highbeam. Anything else to check out?
I had that problem. The dealer wanted me to mortgage my house to buy a new PCM. Someone on this site said it was probably corrosion on the pins underneath the PCM. Yup!! Problem solved, cost $0. 00. Thank you TDR!!!
Yay, that fixed it. That or just disconnecting the power and resetting the system. Should have tested that first. But at least its working and I know where it is and how to get to it.
Did do a little doh though. Circuit breaker for the camper power was in the way. Disconnected it from the battery so I wouldn't zap anything. Sparks fly. Doh, forgot about the camper battery.
