Progress Report - Kinda Long
So long factory headlight switch. Although I don't have all the bugs ironed out, I have done away with the switch. Warning, the way I did it is not for those unwilling to do some surgury. This is for a 97, I don't know how many similarities there are to other years.
I used two relays, one for parking and one for headlights. Using the factory manual, locate the switch plugs on page 8W-80-32.
B1 supplies the headlight power to H. P is also tied in. I think P momentarily supplies extra current when you switch high beam/low beam or maybe hold it so both are on at the same time. I tied B1 & P together.
B2 supplies parking light power to R.
I put the relays in between the source and outputs.
Using a double pole double throw micro switch, I wired the lower position to activate the parking relay. The upper activates the headlights. The upper also has a diode connection to the parking relay. The diode allows the headamps to activate the parking side.
U is a door jamb switch sense. B3 is the key in ignition switch sense. These two circuits are isolated until you put the headlight switch into park or headlamp mode.
I wired U to the center and B3 to both upper and lower switch positions. When either headlights or parking are on, the circuit is made via the double switch.
D is for the cargo lamp. Referring to plug C1, 1 is the courtesy lamp circuit. Both D and C1 work by grounding. These then were simple. I used a micro switch for each.
That said, I will get onto the bug; the reostat. The reostat connects between B2 and I. I smoked a couple of "stats" so far on this so I am still working it out.
I am still working on a switch to do "blink blink" thank you's.
The verdict: Was it worth it? Well, I did away with the drink holder. I was tired of dumping drinks anyway. (The circuitry all slides into that area and the front switch plate fills in the former cup holder area) It is really slick to flip the little micros rather than the "raspy-junky" factory switch. The cargo lights and the courtesy lights work independently and well. My wires going into the factory switch plug were in pretty rough shape so they needed major work anyway. I have ready access to relays and switches, etc. , so I can't give dollar figures on costs.
I am going to continue to work it out, trying different relays, etc. once I get some long term miles on it, I will try to post some drawings and pictures. I just want everyone to know, it can be done.
