Originally posted by David_VT:
IMHO replacing the OEM fuse with these circuits should work. The power will only pass through the circuit when the bulb is grounded via the lightswitch (& hi/lo selector)...
David_Vt... but you actually can not do that, because the oem fuses are Mini (I believe they are ATX size) fuses where as the Zeta's are ATO. So unless someone knows of a mini to ATO fuse adapter, this is impossible.
Make sense?
Kev
