I changed my water pump, thermostat and belt today. I tightened the thermostat housing bolts in a circular pattern with my torque wrench set at 18 ft lbs. until one bolt clicked. The other two bolts kept turning and I started getting nervous that I might be over torqueing. Then one of the bolts snapped and I thought I was in trouble. Luckily the bolt came out easily without the use of an easy out.
At first I thought my torque wrench was out of adjustment, but after looking at the bolts I found that the two bolts that kept turning where about an eighth of an inch longer than the one that torqued to 18 ft lbs. I looked in my parts manual and there was only one part number for these bolts so I knew that they should all be the same length. I'm not sure, but I think the two longer bolts may have been bottoming out before completely tightening down.
Also, after doing a search here on the TDR I found that the service manual lists the wrong torque for these bolts. The service manul lists 18 ft lbs,( 24 nm), but according to some of our members the recommended torque for an 8mm bolt is 9 ft lbs,(12 nm). I also found a couple of instances of members breaking these bolts when torqueing to 18 ft lbs.
I ended up getting some metric grade 10. 9 bolts at the hardware store with 10 MM heads and torqued them to 10 ft lbs. Just a heads up for anyone changing their thermostat.
