Details here: TDR Privileges
If your driver door is sagging any, with the dash out the upper hinge is much easier to replace. I tried the pin-bushing repair but they were not correct size.
It may be covered here on TDR, if not, over on www.dieseltruckresource.com, there is a thread on replacing the heater core. Several guys have cut the long tubes on the heater core, and run heater hose into the cab. They did not have to remove the A/C evaporator. They seemed to be having good luck with that approach.
