Heater does not work . Fan works OK and the heater core gets super hot but the heater only blows cold air . Any ides ?
Your t stat was not open yet. Let it warm up more to be sure the core is at full temp then check heater outlet tempOk I took some temperature readings with my infrared thermometer and here's what I came up with 135 degrees on the heater hose closest to the cylinder head 121 degrees on the hose that is closest to the turbo . 181 degrees at the thermostat housing and 138 degrees on the upper radiator hose .
